Robert I am having no joy with this widget. I do believe it is configured per your example. Any Ideas? In my config file in the UI Element section:<widget left="0" top="0" config="widgets/FeatureTooltip/FeatureTooltipWidget.xml" url="widgets/FeatureTooltip/FeatureTooltipWidget.swf"/>
In my config file in the operationallayers tag:<layer label="Species" type="feature" visible="true" alpha="0"
url="http://www.mapservices.ca/ArcGIS/rest/services/Prima/Prima_Operational/MapServer/5"/>
Layer: Single Stem Species (ID: 5)
Display Field: INGENIERO
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression:
Copyright Text:
Min. Scale: 60000
Max. Scale: 0
Default Visibility: True
Extent:
- XMin: -77.3732140788757
YMin: 6.27068000300208
XMax: -77.3520981540437
YMax: 6.31735493446076
Spatial Reference: 4170
Has Attachments: False
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
The FeatureTooltipWidget.xml:<?xml version="1.0" ?>
<configuration>
<layers>
<layer>
<name>Species</name>
<fields>INGENIERO,ESPECIE,OTRO_OTH,DAP_DBH,longitud</fields>
</layer>
</layers>
</configuration>
