Get "UI" Widget by Id / Label
396
7
04-30-2012 07:48 AM
Drew
Occasional Contributor III
Does teh ESRI Flex Viewer (2.5 +) have any code to get a "UI" widget by Label or ID.
i.e: I want access to the header widget from another widget.
Drew
Drew
Here is my solution...
In the widgetManager.mxml file i had to make the variable "controlContainer" public and added my own function...
                        //=====================================================================    // Get UI Widget by Label.....,. (Make controlContainer PUBLIC)    //=====================================================================    public function getUIWidget(widgetLabel:String):IBaseWidget    {     for (var x:Number = 0; x < controlContainer.numElements; x++)     {      var widget:IBaseWidget = controlContainer.getElementAt(x) as IBaseWidget;      if (widget.widgetTitle.toUpperCase() == widgetLabel.toUpperCase())       return widget;     }          return null;    }
Drew
RobertScheitlin__GISP
Drew,
   Have you tried giving it a label in the main config and using the standard:
ViewerContainer.getInstance().widgetManager.getWidgetId("HeaderControllerLabel")
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Drew
I did try that method before and retested again, but it gives NaN when i try and get a UI element widget.
Drew,
   OK I see the issue... You need to replace your WidgetManager.mxml  getWidgetId function with this one.
             * @return Returns the widget ID for a specific widget based on the widget label.
            public function getWidgetId(widgetLabel:String, isController:Boolean = false):Number
                var id:Number = Number.NaN;
                if (isController){
                    for (var c:Number = 0; c < configData.controls.length; c++)
                        if (configData.controls.label == widgetLabel)
                            id = configData.controls.id;
                }else{
                    for (var w:Number = 0; w < configData.widgets.length; w++)
                        if (configData.widgets.label == widgetLabel)
                            id = configData.widgets.id;
                return id;
and use this code:
ViewerContainer.getInstance().widgetManager.getWidgetId("hc",true)
The new second optional parameter tells the function you are looking for a UI Widget (controller).
Drew
Thanks for the code Robert.
It works to get the widget ID, but when i try and find the widget i hit and error.
Error
public function getWidget(widgetId:Number, openWidgetIfNot:Boolean = false):IBaseWidget
if (idx == null)
   throw new ArgumentError("Invalid widgetId: " + widgetId);
My widget id comes back as ID = 1007
my code
var wid:Number =  ViewerContainer.getInstance().widgetManager.getWidgetId("MyWidgetLabel",true);
var widget:IBaseWidget =  ViewerContainer.getInstance().widgetManager.getWidget(wid);
I might end up making my own public collection to hold these widgets in so I can find them.
Drew
Drew
Drew
Drew,
   Glad you got that working. Don't forget to mark YOUR post as the answer then.
Drew
Thanks for your help Rob. It guided me into the right direction.
Post marked!
Drew
