How do you get the time slider to even show up in your widget? When I run my application its nowhere to be found.It looks like I have it in my code but it does not show up when I run the application<configuration>
<layers>
<layer>
<name>Date Installed HeatMap</name>
<url>http://gis02/ArcGIS/rest/services/Random/GravitySewerValuation/MapServer/0</url>
<outFields>EYI</outFields>
<useproxy>false</useproxy>
<useamf>true</useamf>
<defaultquery>1=1</defaultquery>
<querytemplate>EYI = REPLACE_STR</querytemplate>
<types>1910,1950,1960,1980,1985,1995,2000,2005</types>
<type_descs>Date Installed = 1910,Date Installed = 1950,Date Installed = 1960,Date Installed = 1980,Date Installed = 1985,Date Installed = 1995,Date Installed = 2000,Date Installed = 2005</type_descs>
</layer>
</layers>
<ui>
<widget_dimensions>
<width>378</width>
<height>206</height>
</widget_dimensions>
<icons>
<base_url>widgets/HeatMap/assets/</base_url>
<main_icon>i_rainbow.png</main_icon>
<main_label>Main Panel</main_label>
<settings_icon>i_options.png</settings_icon>
<settings_label>Settings Panel</settings_label>
</icons>
<refresh_label>refreshing layer...</refresh_label>
<query>
<comp_label>Earthquake Magnitude:</comp_label>
<heatmapquery_prompt>default selection</heatmapquery_prompt>
<featurecount_label>features contained</featurecount_label>
</query>
<timeslider>
<loop>true</loop>
<thumbcount>2</thumbcount>
<thumbmovingrate>1200</thumbmovingrate>
<dateformat>MMM,yyyy</dateformat>
</timeslider>
<transparency>
<comp_label>Transparency:</comp_label>
<defaulttransparency>0.8</defaulttransparency>
</transparency>
<symbol>
<comp_label>Theme:</comp_label>
<defaulttheme>RAINBOW</defaulttheme>
</symbol>
</ui>
</configuration>
Jerry
