Heat map widget question
622
07-30-2012 03:41 AM
JerryBiedenbender
Hello,
Excellent widget but i need some help modifying it.
        Instead of greater than or equal to... Can I do a "between". I have over 100 years of data and i would like to display it by 5 or 10 years at a time rather than year by year.
Below is an example of how it looks year by year by but if i keep this up the list will be too big.
<querytemplate>RSL = REPLACE_STR</querytemplate>
            <types>0,1,2,3,4,5</types>
            <type_descs>Years = 0,Years = 1,Years = 2,Years = 3,Years = 4,Years = 5</type_descs>
Is there code like this...
<type_descs>Years Between (0&5),Years Between (5&10), Years Between (10&15), Years Between (15&20)</type_descs>
Jerry
philippschnetzer
Occasional Contributor III
I was able to change the step intervals not by changing the code in the widget, but rather changing the values in layer properties in ArcMap...look under Layer Properties --> Time, and then change the Time Step Interval and those changes should be reflected in your app.
JerryBiedenbender
How do you get the time slider to even show up in your widget? When I run my application its nowhere to be found.
It looks like I have it in my code but it does not show up when I run the application
<configuration>
    <layers>
        <layer>
            <name>Date Installed HeatMap</name>
            <url>http://gis02/ArcGIS/rest/services/Random/GravitySewerValuation/MapServer/0</url>
            <outFields>EYI</outFields>
            <useproxy>false</useproxy>
            <useamf>true</useamf>
            <defaultquery>1=1</defaultquery>
            <querytemplate>EYI = REPLACE_STR</querytemplate>
            <types>1910,1950,1960,1980,1985,1995,2000,2005</types>
            <type_descs>Date Installed = 1910,Date Installed = 1950,Date Installed = 1960,Date Installed = 1980,Date Installed = 1985,Date Installed = 1995,Date Installed = 2000,Date Installed = 2005</type_descs>
        </layer>
    </layers>
    <ui>
        <widget_dimensions>
            <width>378</width>
            <height>206</height>
        </widget_dimensions>
        <icons>
            <base_url>widgets/HeatMap/assets/</base_url>
            <main_icon>i_rainbow.png</main_icon>
            <main_label>Main Panel</main_label>
            <settings_icon>i_options.png</settings_icon>
            <settings_label>Settings Panel</settings_label>
        </icons>
        <refresh_label>refreshing layer...</refresh_label>
        <query>
            <comp_label>Earthquake Magnitude:</comp_label>
            <heatmapquery_prompt>default selection</heatmapquery_prompt>
            <featurecount_label>features contained</featurecount_label>
        </query>
        <timeslider>
            <loop>true</loop>
            <thumbcount>2</thumbcount>
            <thumbmovingrate>1200</thumbmovingrate>
            <dateformat>MMM,yyyy</dateformat>
        </timeslider>
        <transparency>
            <comp_label>Transparency:</comp_label>
            <defaulttransparency>0.8</defaulttransparency>
        </transparency>
        <symbol>
            <comp_label>Theme:</comp_label>
            <defaulttheme>RAINBOW</defaulttheme>
        </symbol>
    </ui>
</configuration>
Jerry
philippschnetzer
I'm using the 2.5 compiled version.  Here is my configuration file contents:
<?xml version="1.0" ?>
<configuration>
 <layers>
        <layer>
            <name>(layer name matched with the layers name in your main config.xml)</name>
            <url>http://www.xxxxxxxxxxxxxxxx.com/ArcGIS/rest/services/xxxxxxxxxxxxxx/FeatureServer/1</url>
            <outFields>Date_Submi,Contribu_1</outFields>
   <querytemplate></querytemplate>
   <types></types>
   <type_descs></type_descs>
        </layer>
 </layers>
 <ui>
  <widget_dimensions>
   <width>1</width>
   <height>1</height>
  <icons>
   <main_icon>i_rainbow.png</main_icon><!-- Icon must exist under assets/images in viewer -->
   <main_label>Main Panel</main_label><!-- Title/label for icon across the top widget panel -->
  </icons>
  <query>
   <featurecount_label> features contained</featurecount_label>
  </query>
  <transparency>
   <defaulttransparency>0.4</defaulttransparency>
  </transparency>
  <symbol>
   <defaulttheme>RAINBOW</defaulttheme><!-- Must be one of RED_WHITE_BLUE, RAINBOW, or THERMAL -->
  </symbol>
 </ui>
</configuration>
And then, like I said earlier, I used the Time properties through layer properties in ArcMap to manipulate the time step interval.
