heatmap-widget-flex
2834
01-24-2013 10:20 AM
LloydHeberlie
This is the new forum for asking questions related to the ArcGIS Viewer for Flex HeatMapWidget hosted on GitHub (https://github.com/Esri/heatmap-widget-flex) and referenced on ArcGIS.com.
You may also find the previous thread Heat-Map-on-ArcGIS-Viewer-for-Flex helpful.
EzequiasRodrigues_da_Rocha
New Contributor III
I am having trouble to build the source code in my flex viewer 3.6. I just copied the widget module and the samples folder to my project but it didn't work.
By the way, could you make xml-editable the "Time Enabled" label and the "On/Off" button label?
Your widget is awesome.
Regards
Ezequias Rocha
