Error # 2032 in Flex Viewer
3725
02-13-2014 06:38 PM
ChapalChoudhury
Hi All,
Some of our users are getting an error message �??2032�?� while running a Flex Viewer 3.3 Webmap application.
I have tested with different users and it seems that users that do not have Internet access (Intranet only) CANNOT browse the Webmap and the 2032 error message pops up. The test was done on the same PC using the same IE version.
Note: Our ArcGIS Server 10.1 and IIS 6.0 Server are both installed on the same machine (Windows Server 2003 SP2) and connection to Internet from these machines are Blocked as part of corporate security policy.
We have had our Server team investigate and they found that when you open the http://�?�./FlexViewer/index.html site it immediately tries to access the below URLs on the Internet. It seems to be Flex Viewer�??s Index.html is sending the request to connect to the Internet.
[ATTACH=CONFIG]31427[/ATTACH]
Can anyone please advise if any changes can be made in the Flex Viewer to stop / disable the attempts to connect to the Internet?
Chapal
AnthonyGiles
Chapel,
If you open your index.html file in a text editor like notepad you will see there a couple of script elements that check to see if the latest flash player is installed. If you comment these out the browser should not try and reach out to the internet.
Regards
Anthony
GISDev1
Occasional Contributor III
Are you using your own basemaps as well? If you are, then removing the flash player version check above should be all you need like said above. If you're using Esri or Bing basemaps, then you might have an issue with that.
ChapalChoudhury
Hi Anthony, Hi GISDev01,
I've commneted out the two red-marked sections in the Index.html file as shown below. But it's still trying connecting to fpdownload.adobe.com site for a crossdomain.xml file, please see the attached screenshot from Fiddler. Note, the crossdomain.xml file is already present in my wwwroot folder and all map services and data are running internally on our ArcGIS server. The ArcGIS, IIS and geodatabase servers are all under same domain anyway. There is no need to connect to any other online services.
Thanks in advance for your help.
Regards,
Chapal
[ATTACH=CONFIG]31499[/ATTACH]
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
<head>
<title>ArcGIS Viewer for Flex</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="description" content="Esri ArcGIS viewer for Flex"/>
<meta name="keywords" content="Esri, ArcGIS, Flex Viewer"/>
<meta name="author" content="Esri"/>
<!-- Include CSS to eliminate any default margins/padding and set the height of the html element and
the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as
the percentage of the height of its parent container, which has to be set explicitly. Fix for
Firefox 3.6 focus border issues. Initially, don't display flashContent div so it won't show
if JavaScript disabled.
<style type="text/css" media="screen">
html, body { height:100%; }
body { margin:0; padding:0; overflow:auto; text-align:center;
background-color: #ffffff; }
object:focus { outline:none; }
#flashContent { display:none; }
</style>
<!-- Enable Browser History by replacing useBrowserHistory tokens with two hyphens -->
<!-- BEGIN Browser History required section >
<link rel="stylesheet" type="text/css" href="history/history.css" />
<script type="text/javascript" src="history/history.js"></script>
<! END Browser History required section -->
<script type="text/javascript" src="swfobject.js"></script>
<script type="text/javascript">
// For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection.
var swfVersionStr = "0.0.0";
// To use express install, set to playerProductInstall.swf, otherwise the empty string.
var xiSwfUrlStr = "playerProductInstall.swf";
var flashvars = {};
flashvars.localeChain = "en_US";
flashvars.resourceModuleURLs = "assets/locale/en_US.swf";
//flashvars.localeChain = "ar";
//flashvars.resourceModuleURLs = "assets/locale/ar.swf";
//flashvars.localeChain = "da_DK";
//flashvars.resourceModuleURLs = "assets/locale/da_DK.swf";
//flashvars.localeChain = "de_DE";
//flashvars.resourceModuleURLs = "assets/locale/de_DE.swf";
//flashvars.localeChain = "es_ES";
//flashvars.resourceModuleURLs = "assets/locale/es_ES.swf";
//flashvars.localeChain = "et_EE";
//flashvars.resourceModuleURLs = "assets/locale/et_EE.swf";
//flashvars.localeChain = "fi_FI";
//flashvars.resourceModuleURLs = "assets/locale/fi_FI.swf";
//flashvars.localeChain = "fr_FR";
//flashvars.resourceModuleURLs = "assets/locale/fr_FR.swf";
//flashvars.localeChain = "he_IL";
//flashvars.resourceModuleURLs = "assets/locale/he_IL.swf";
//flashvars.localeChain = "it_IT";
//flashvars.resourceModuleURLs = "assets/locale/it_IT.swf";
//flashvars.localeChain = "ja_JP";
//flashvars.resourceModuleURLs = "assets/locale/ja_JP.swf";
//flashvars.localeChain = "ko_KR";
//flashvars.resourceModuleURLs = "assets/locale/ko_KR.swf";
//flashvars.localeChain = "lt_LT";
//flashvars.resourceModuleURLs = "assets/locale/lt_LT.swf";
//flashvars.localeChain = "lv_LV";
//flashvars.resourceModuleURLs = "assets/locale/lv_LV.swf";
//flashvars.localeChain = "nb_NO";
//flashvars.resourceModuleURLs = "assets/locale/nb_NO.swf";
//flashvars.localeChain = "nl_NL";
//flashvars.resourceModuleURLs = "assets/locale/nl_NL.swf";
//flashvars.localeChain = "pl_PL";
//flashvars.resourceModuleURLs = "assets/locale/pl_PL.swf";
//flashvars.localeChain = "pt_BR";
//flashvars.resourceModuleURLs = "assets/locale/pt_BR.swf";
//flashvars.localeChain = "pt_PT";
//flashvars.resourceModuleURLs = "assets/locale/pt_PT.swf";
//flashvars.localeChain = "ro_RO";
//flashvars.resourceModuleURLs = "assets/locale/ro_RO.swf";
//flashvars.localeChain = "ru_RU";
//flashvars.resourceModuleURLs = "assets/locale/ru_RU.swf";
//flashvars.localeChain = "sv_SE";
//flashvars.resourceModuleURLs = "assets/locale/sv_SE.swf";
//flashvars.localeChain = "zh_CN";
//flashvars.resourceModuleURLs = "assets/locale/zh_CN.swf";
var params = {};
params.quality = "high";
params.bgcolor = "#ffffff";
params.allowscriptaccess = "sameDomain";
params.allowfullscreen = "true";
var wmode = swfobject.getQueryParamValue("wmode");
if (wmode)
params.wmode = wmode;
var attributes = {};
attributes.id = "index";
attributes.name = "index";
attributes.align = "middle";
swfobject.embedSWF(
"index.swf", "flashContent",
"100%", "100%",
swfVersionStr, xiSwfUrlStr,
flashvars, params, attributes);
// JavaScript enabled so display the flashContent div in case it is not replaced with a swf object.
swfobject.createCSS("#flashContent", "display:block;text-align:left;");
if (swfobject.ua.ie && swfobject.ua.win)
swfobject.addLoadEvent(
function()
var app = swfobject.getObjectById("index");
if (app)
app.focus();
</script>
</head>
<body>
<!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough
JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show
when JavaScript is disabled.
<div id="flashContent">
<p>
To view this page ensure that Adobe Flash Player version
11.1.0 or greater is installed.
</p>
var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://");
document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='"
+ pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" );
</script>
--> </div>
<noscript>
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="100%" height="100%" id="index">
<param name="movie" value="index.swf" />
<param name="quality" value="high" />
<param name="bgcolor" value="#ffffff" />
<param name="allowScriptAccess" value="sameDomain" />
<param name="allowFullScreen" value="true" />
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="index.swf" width="100%" height="100%">
<!--<![endif]-->
<!--[if gte IE 6]>-->
<p>
Either scripts and active content are not permitted to run or Adobe Flash Player version
11.1.0 or greater is not installed.
</p>
<!--<![endif]-->
<a href="http://www.adobe.com/go/getflashplayer">
<img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" />
</a>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</noscript>
</body>
</html>
