<?xml version="1.0" ?> <configuration> <locator>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</locator> <keepinspectoractive>true</keepinspectoractive> <usesearchextent>true</usesearchextent> <minscore>40</minscore> <zoomscale>10000</zoomscale> <pointunits> <pointunit abbr="wgs84dd" example="-85.8337, 33.6531" wkid="4326" xlabel="Longitude:" ylabel="Latitude:">Decimal Degrees (WGS84)</pointunit> <pointunit abbr="none" example="594139.135, 2369958.8" wkid="32640" xlabel="Easting(x)" ylabel="Northing(x)">WGS 1984 UTM Zone 40N</pointunit> </pointunits> <labels> <descriptionlabel>Use the inspect address tool to click on the map and locate the address:</descriptionlabel> </labels> <symbols> <geopicturemarkersymbol url="widgets/eLocate/assets/images/i_house.png" height="30" width="30" xoffset="0" yoffset="0" angle="0"/> <coordpicturemarkersymbol url="assets/images/i_pin.png" height="30" width="30" xoffset="0" yoffset="0" angle="0"/> </symbols> <initialview>null</initialview> </configuration>
Solved! Go to Solution.
