Robert -
First off, this is an awesome widget. However, I am having an issue with the widegt with regards to hyperlinks. I see from the documentation that I can define via <linkfield></linkfield> a feature class attirbute that contains a URL and should be able to access that URL by clicking. My issue is two fold.
1. The attribute I am defining is titled, fittingly enough, HYPERLINK and contains a UNC path to a pdf document containing additional information on the particular feature. The HYPERLINK attribute is often returned as NULL in the Identify Results window even though there should be a URL there.
2. When I do use <linkfield></linkfield>, then the HYPERLINK attribute is not even listed in the Results window. For Issue #1 above, I did not define the <linkfield></linkfield>.
I am running a Flex Viewer 2.4 webservice off an ArcGIS 10 SDE database.
Can you think of what I might be doing incorrectly or have I identified a previously unidentified bug (and if so, do I get a prize? )?
You help would be greatly appreciated.
Michael Hanna
Middlesex Water Company
