Link support in new 2.3 popups
2552
13
04-19-2011 09:48 AM
JonFisher
New Contributor III
Can anyone confirm if the new popups in the 2.3 viewer have linkfield support, and if so how to configure it? The help link (http://help.arcgis.com/en/webapps/flexviewer/help/01m3/01m300000013000000.htm) still shows the old configuration and none of the new examples include links. I can see that I could use the description tag to set up a link, but then the fields tag is ignored (so I'd need to put them all in the description). I tried adding the linkfield to fields, and then adding <link>{ERA_REPT}</link> (I also tried <linkfield>{ERA_REPT}</linkfield>) after title and before the fields but that didn't work.
Can someone clarify if the only link support is via <description> as opposed to having a link icon?
Jon
RobertScheitlin__GISP
JonFisher
New Contributor III
Thanks! It's funny that with all the things I tried I didn't try simply making the field visible to see if it was clickable or not. It's great that links are automatically recognized now (including photos being embedded).
JonFisher
New Contributor III
Whoops, I spoke too soon. When I mouseover a record in the Query widget, I see the new popup with the properly embedded picture (see attached ViaQuery.jpg).
However, WITHOUT the Query widget open, if I simply configure the popup to display the field that has the photo links it just shows up as a link (NoPhoto.jpg):
<configuration>
    <title>{DESC_}</title>
    <fields>
        <field name="DESC_"/>
        <field name="HYPERLINK" visible="true"/>
    </fields>
</configuration>
I also tried using the <description> tag, and found that if I include {HYPERLINK} the picture is embedded but the height doesn't expand to show the whole picture (see CutOffPhoto.jpg). If I use <img src="{HYPERLINK}"/> nothing is displayed at all. In the code below I have it both ways, but you get the same result with just {HYPERLINK} w/out the img src bit.
<?xml version="1.0" ?>
<configuration>
 <description><![CDATA[<a href="{HYPERLINK}"><img src="{HYPERLINK}"/>{HYPERLINK}</a>.<br>a. ]]>
    </description>
    <fields>
        <field name="HYPERLINK" />
    </fields>
</configuration>
So can someone clarify the proper way to have embedded photos properly handled by the new popups without having to use the Query widget?
JonFisher
New Contributor III
Sorry, I forgot the attachments; they are now attached here.
Jon,
   If the link is to an image than you need to setup a media tag:
<configuration>
    <fields>
        <field name="HYPERLINK"/>
    </fields>
    <medias>
        <media chartfields="" type="image" caption="" imagesource="{HYPERLINK}" imagelink="{HYPERLINK}"/>
    </medias>
</configuration>
JonFisher
New Contributor III
Ah! You're the best Robert! I'm pretty helpless until the documentation gets updated. That worked great.
haThach
New Contributor III
Hi Robert,
I have a "HyperLink" field contain a path that link to .pdf file. How do I show a small pdf icon without displaying the full path.
<configuration>
    <title>{EXTENSION_GIS}</title>
    <fields>
  <field name="EXTENSION_GIS" alias="Extension:" visible="true"/>
  <field name="INSTALL_YEAR" alias="Year:" visible="true"/>
  <field name="HyperLink" alias="HyperLink:" visible="true"/>
</fields>
</configuration>
Thanks in advance.
Ha Thach
Ha Thach,
   That is not currently possible with out extending the PopUpRendererSkin component of the API.
haThach
New Contributor III
Thanks! Robert for this quick response.
Ha
