MGRS Widget for Flex Viewer
6171
47
02-15-2012 08:37 PM
MarcGraham
Has anyone got a compiled widget for the Flex Viewer that returns the current cursor location as an MGRS grid?
It would be great if it worked with multiple coordinate systems.
regards,
Marc
AuraRamos_Lora
New Contributor II
If it works but not so well in the new version 3.1, any idea???
Thanks for the help
Regards...
AnthonyGiles
I'm just in the process of updating to 3.1 at the moment. I have had to go back to Kerry Coffin who works for ESRI in the states as the compiled libraries that I am using seem to place the grid in the wrong place. I will update as soon as I can.
Regards
Anthony
darrencassin
Hi Tony,
Do you know if it's possible to create a "goto long/lat function" which is similar to the "Goto USNG function"
AnthonyGiles
Darren,
There are plenty of options to do this, have a look at using a locator or the coordinate menu widget:
http://www.arcgis.com/home/item.html?id=edd4a2b7c722493a8b08f53eaa131e1e
Regards
Anthony
AuraRamos_Lora
New Contributor II
Regards
Anthony
You're right appears the gradicula out of phase, rightly  I´ve reviewed the code and I did not see anything abnormal, so are the libraries.
I wish you luck in finding in making these changes of libraries
Thanks Anthony  for your help and please ask you to keep us informed.
It is a great contribution, thanks again.
Regards
OlegLukyanov
New Contributor III
I couldn't import this widget because widget name conflict with existing Coordinate widget name.
Help please.
Thanks.
GeorgeHaskett
Occasional Contributor III
Help please.
Thanks.
Oleg,
Are you trying to use the default coordinate widget as well or is the error when you are trying to import this widget within the application builder?
If its the later, then build the base of the web app via the builder and add the custom widget via the tag references and NOT via the application builder.  You can find ample info at ESRI's Viewer for Flex help site.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Widget_tag/01m30000001w000000/
Haskett
