Navigation tools are disabled in editor mode
1729
06-19-2014 12:12 PM
ronaldmcfarlane
I am using Flexviewer 3.6 & ArcGIS Server 10.1.  I have a map containing the Navigation widget and the Edit widget.  If not editing all nav functions work, when I open the the Edit widget, the zoom-in/zoom-out buttons in the nav widget are greyed out and cannot be activated.  When I close the Edit widget it all works again.  Both widgets are ESRI's out of the box, unmodified.  Any ideas (and am I the only one with this problem)?
R__CraigHolmes
You are not alone.  Pan too (3.6, 10.2)
BjornSvensson
...when I open the the Edit widget, the zoom-in/zoom-out buttons in the nav widget are greyed out...
You can see the same behavior in the Edit widget sample at http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-edit.xml
All the mouse and keyboard navigation is still available, for example:
ronaldmcfarlane
Why is it disabled?  If no good reason, can it be enabled (or is it a bug)?
