No operational layers available Attribute table widget
4110
04-28-2015 08:32 AM
IeuanHarry1
New Contributor III
Im creating a web viewer using the Viewer for Flex V3.7. I have 3 services present in the viewer and wish to use the Attribute Table widget. When I want to Edit the functionality of the widget it says there are no operational Layers available even though these layers load up in the viewer
RobertScheitlin__GISP
Leuan,
   DO you have your operational layers loaded as whole mapservices or as individual feature layers
IeuanHarry1
New Contributor III
Map services i believe
Leuan,
   It would help if you could share your main config.xml
