Mark, You need to make sure you are very clear with your questions and have an exact desired direction you are attempting to achieve when you ask question on the forums. If you post generic questions or comments (like "showing additional as well") you are less likely to receive any response. Toggling a operational layer on or off is very simple and can easily be done in the popup Skin: override protected function commitProperties():void { super.commitProperties(); var featureLayer:FeatureLayer = hostComponent.featureLayer; var formattedAttributes:Object = hostComponent.formattedAttributes; var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var popUpInfo:PopUpInfo = hostComponent.popUpInfo; var validMediaInfos:Array = hostComponent.validPopUpMediaInfos; var geometry:Geometry = graphic ? graphic.geometry : null; var layerDetails:LayerDetails = featureLayer ? featureLayer.layerDetails : null; vGroup.removeAllElements(); vGroup.addElement(ToggleLayers); if (popUpInfo) { if (popUpInfo.title) { titleText.text = StringUtil.substitute(popUpInfo.title, formattedAttributes); if (titleText.text) { vGroup.addElement(titleText); vGroup.addElement(titleLine); } } var htmlText:String; if (popUpInfo.description) { htmlText = StringUtil.substitute(popUpInfo.description, formattedAttributes); if (htmlText) { var descriptionText:Text = new PopUpText(); descriptionText.percentWidth = 100; descriptionText.styleSheet = textStyleSheet; cleanAndSetHtmlText(descriptionText, htmlText); trace(descriptionText.htmlText); vGroup.addElement(descriptionText); } } else { var descriptionForm:Form; for each (var fieldInfo:PopUpFieldInfo in popUpInfo.popUpFieldInfos) { if (fieldInfo.visible) { var formItem:FormItem = new FormItem(); formItem.label = fieldInfo.label || fieldInfo.fieldName; var label:Label; htmlText = formattedAttributes[fieldInfo.fieldName]; if (htmlText) { // convert attribute field values that just contain URLs into links var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i); if (match && match.length > 0) { label = new Label(); htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>"; } else { label = new PopUpText(); } cleanAndSetHtmlText(label, htmlText); label.selectable = true; label.styleSheet = this.textStyleSheet; label.width = 150; formItem.addChild(label); } if (!descriptionForm) { descriptionForm = new Form(); descriptionForm.percentWidth = 100; descriptionForm.horizontalScrollPolicy = ScrollPolicy.OFF; descriptionForm.verticalScrollPolicy = ScrollPolicy.OFF; descriptionForm.styleName = "formStyle"; } descriptionForm.addChild(formItem); } } if (descriptionForm) { vGroup.addElement(descriptionForm); } } if (validMediaInfos && validMediaInfos.length > 0) { vGroup.addElement(mediaBrowser); mediaBrowser.attributes = graphic.attributes; mediaBrowser.formattedAttributes = formattedAttributes; mediaBrowser.popUpFieldInfos = popUpInfo.popUpFieldInfos; mediaBrowser.popUpMediaInfos = validMediaInfos; } if (popUpInfo.showAttachments && graphic && featureLayer && layerDetails && layerDetails.hasAttachments && layerDetails.objectIdField) { vGroup.addElement(attachmentInspector); attachmentInspector.showAttachments(graphic, featureLayer); } if (map && geometry) { vGroup.addElement(zoomToButton); } } } protected function layerRBgroup_changeHandler(event:Event):void { var map:Map = hostComponent.map; map.getLayer("Public Safety").visible = !map.getLayer("Public Safety").visible; map.getLayer("Bridges").visible = !map.getLayer("Bridges").visible; } ]]> </fx:Script> <fx:Declarations> <!--- @private --> <mx:Text id="titleText" width="100%" fontWeight="bold"/> <!--- @private --> <s:Line id="titleLine" width="100%"> <s:stroke> <s:SolidColorStroke id="titleLineSymbol" color="black" weight="1"/> </s:stroke> </s:Line> <!--- @private --> <supportClasses:PopUpMediaBrowser id="mediaBrowser" width="100%" skinClass="com.esri.ags.skins.supportClasses.PopUpMediaBrowserSkin"/> <!--- @private --> <esri:AttachmentInspector id="attachmentInspector" width="100%" addEnabled="false" deleteEnabled="false"/> <!--- @private --> <mx:LinkButton id="zoomToButton" click="zoomToButton_clickHandler(event)" fontWeight="bold" label="{resourceManager.getString('ESRIMessages', 'zoomLabel')}"/> <!--- @private --> <s:RadioButtonGroup id="layerRBgroup" change="layerRBgroup_changeHandler(event)"/> <!--- @private --> <s:HGroup gap="6" verticalAlign="middle" id="ToggleLayers"> <s:RadioButton id="layerA" group="{layerRBgroup}" label="Toggle Layer A" selected="true"/> <s:RadioButton id="layerB" group="{layerRBgroup}" label="Toggle Layer B"/> </s:HGroup> </fx:Declarations>
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
