<operationallayers> <layer label="XYZ Test of Edit" type="dynamic" visible="false" alpha="1.0" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer"/> <layer label="Editable Features" type="feature" visible="true" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/test.xml" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer/0"/> </operationallayers>
Feature Layer: EditLines (ID: 0) View In: ArcGIS.com Map Display Field: SITECODE Type: Feature Layer Geometry Type: esriGeometryPolyline Description: Copyright Text: Min. Scale: 0 Max. Scale: 0 Extent: XMin: 559357.9375 YMin: 114810.068100002 XMax: 594669.064499997 YMax: 153591.5735 Spatial Reference: 32149 Drawing Info: Renderer: Simple Renderer: Symbol: Simple Line Symbol: Style: esriSLSSolid, Color: [161, 0, 56, 255], Width: 1 Label: Lines Description: Transparency: 0 Labeling Info: N/A Has Attachments: False HTML Popup Type: esriServerHTMLPopupTypeNone Object ID Field: OBJECTID Global ID Field: Type ID Field: Fields: OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID, Editable: False) DEC_UNIT (Type: esriFieldTypeString, Alias: DEC_UNIT, Length: 15, Editable: True, Domain: Coded Values: [100-B/C: 100-B/C], [100-D/H: 100-D/H], [100-F/IU-2/IU-6: 100-F/IU-2/IU-6], ...5 more...) Templates: Name: EditLines Description: Drawing Tool: esriFeatureEditToolLine Prototype: Attributes: DEC_UNIT: Supported Interfaces: REST Supported Operations: Query Add Features Update Features Delete Features Apply Edits
Is this possible with the editwidget or some other widget: Allow users via the webviewer to click on a feature in a featurelayer and have a popup show the value for a particular field for that featuer and allow the user to edit that value (from a dropdown of selections)? I don't see how to do this. Any help is appreciated.
Yes, that is possible with the Edit widget. Your data needs to be coming from an ArcGIS Server Feature Service (and be editable).
See http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Edit_widget/01m30000003v000000/
Live sample: http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-edit.xml
Is there a walk-through example of creating template? I only have one attribute I want to be updatable (click on the existing feature and have a drop down selection of 1,2,3 or 4), no drawing/adding features.
Feature Layer: XYZ.PavementBranch (ID: 0) View In: ArcGIS.com Map Display Field: FEATURENAME Type: Feature Layer Geometry Type: esriGeometryPolygon Description: Copyright Text: Min. Scale: 0 Max. Scale: 0 Extent: XMin: -5.63324851099998 YMin: 36.984785175 XMax: 35.456580847 YMax: 56.174739496 Spatial Reference: 4326 Drawing Info: Renderer: Unique Value Renderer: Field 1: PCI Field 2: Field 3: Field Delimiter: , Default Symbol: Unsupported Symbol Default Label: Unique Value Infos: Value: 0 Label: CLEAR Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [182, 252, 184, 255] Outline: Simple Line Symbol: Style: esriSLSSolid, Color: [110, 110, 110, 255], Width: 0.4 Value: 1 Label: Test Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [255, 190, 190, 255] Outline: Simple Line Symbol: Style: esriSLSSolid, Color: [0, 0, 0, 255], Width: 0.4 Value: 2 Label: Test2 Description: Symbol: Simple Fill Symbol: Style: esriSFSSolid, Color: [190, 232, 255, 255] Outline: ... Simple Line Symbol: Style: esriSLSSolid, Color: [0, 0, 0, 255], Width: 0.4 Transparency: 0 Labeling Info: N/A Has Attachments: False HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText Object ID Field: OBJECTID Global ID Field: GLOBALID Type ID Field: PCI Fields: ... PCI (Type: esriFieldTypeInteger, Alias: PavementConditionIndex, Editable: True) ... Types: ... ... -------------------------------------------------------------------------------- Supported Interfaces: REST Supported Operations: Query Add Features Update Features Delete Features Apply Edits
<operationallayers> <layer label="XYZ Test of Edit" type="dynamic" visible="false" alpha="1.0" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer"/> <layer label="Editable Features" type="feature" visible="false" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/test.xml" url="https://url.com/ArcGIS/rest/services/XYZ/FeatureServer/0"/> </operationallayers> <widget label="Edit Test" icon="assets/images/i_edit.png" config="widgets/Edit/EditWidget.xml" url="widgets/Edit/EditWidget.swf"/>
<?xml version="1.0" ?> <configuration> <createoptions> <polygondrawtools>polygon,freehandpolygon,extent,autocomplete</polygondrawtools> <polylinedrawtools>polyline,freehandpolyline,line</polylinedrawtools> </createoptions> <addfeatures>true</addfeatures> <deletefeatures>true</deletefeatures> <toolbarvisible>true</toolbarvisible> <toolbarcutvisible>true</toolbarcutvisible> <toolbarmergevisible>true</toolbarmergevisible> <toolbarreshapevisible>true</toolbarreshapevisible> <updategeometry>true</updategeometry> <updateattributes>true</updateattributes> <showcreatorfield>true</showcreatorfield> <showcreationdatefield>true</showcreationdatefield> <showeditorfield>true</showeditorfield> <showeditdatefield>true</showeditdatefield> </configuration>
ID: Sprayed Name: Sprayed Domains: Field Name: INSTALLATIONID Inherited Field Name: SITEID Inherited Field Name: REALPROPERTYSITEUNIQUEID Inherited Field Name: OWNER Inherited Templates: Name: Sprayed Description: Drawing Tool: esriFeatureEditToolPolygon Prototype: Attributes: PRIORITY: None STATUS: Sprayed -------------------------------------------------------------------------------- ID: Plowed Name: Plowed Domains: Field Name: INSTALLATIONID Inherited Field Name: SITEID Inherited Field Name: REALPROPERTYSITEUNIQUEID Inherited Field Name: OWNER Inherited Templates: Name: Plowed Description: Drawing Tool: esriFeatureEditToolPolygon Prototype: Attributes: PRIORITY: None STATUS: Plowed
