removeTitlebarButton ? (addTitlebarButton)
383
05-02-2012 05:11 AM
JanPacak
Hello,
i have a one question. Exists a function as removeTitlebarButton? I need remove a icon from header of widget after action (e.g. after click on button) I know addTitlebarButton but I can't find a remove function. Can anybody help me?
Thanks
IvanBespalov
Occasional Contributor III
I can't find a remove function too,
but
ESRI Viewer is extandable application
you can extend WidgetTemplate.as as you want (this code is just a sample - not tested)
// Viewer version is 2.5
    public function addTitlebarButton(btnIcon:String, btnTip:String, btnFunction:Function, selectable:Boolean = true):void
        var btn:TitlebarButton = new TitlebarButton();
        btn.callback = btnFunction;
        btn.selectable = selectable;
        btn.source = btnIcon;
        btn.toolTip = btnTip;
        if (selectable)
            btn.addEventListener(MouseEvent.CLICK, titlebarButton_clickHandler);
            if (headerToolGroup.numElements == 0)
                selectedTitlebarButtonIndex = 0; // automatically select the first button added
        headerToolGroup.addElement(btn);
 public function removeTitlebarButton(item:TitlebarButton):Boolean
  var success:Boolean = false;
  // next logic is the same as in headerToolGroup.removeElement(...)
  if (item != null)
   try
    var buttonIndex:int = headerToolGroup.getElementIndex(item);
    if (buttonIndex > -1)
     headerToolGroup.removeElementAt(buttonIndex);
     success = true;
   catch (error:ArgumentError) // child element not exists in headerToolGroup
    trace(error.getStackTrace());
  return success;
JanPacak
Many thanks Ivan. Your idea help me and it fixed my problem.
