Viewer for Silverlight related data not visible
4044
8
10-03-2013 05:51 AM
FilipNevistic
Hello!
We created Relationship Class in ArcGIS Catalog.[ATTACH=CONFIG]28000[/ATTACH]
All created relations are visible in ArcGIS Map.[ATTACH=CONFIG]28001[/ATTACH]
We created application in Viewer for Silverlight, with ShowRelatedRecords Tool added in.
After application is created and started, point click triggers pop-up window and main attribute table is shown.
In right corner of pop-up window ShowRelatedRecords Tool icon is shown. If we click on this icon, related data table appears.
Then pop-up window is closed, and after another click on next point, ShowRelatedRecords icon is hidden from pop-up window and we can see only main attribute table.
[ATTACH=CONFIG]28002[/ATTACH]
Does anyone have solution for this problem?
How to adjust query tool to query related tables/records?
Thanks!
by Anonymous User
Not applicable
Original User: bangel
Do you have Feature Access enabled in the service properties for the service with related data?
FilipNevistic
Yes, Feature Access is enabled.
[ATTACH=CONFIG]28159[/ATTACH]
This is also enabled.
Any other idea?
by Anonymous User
Not applicable
My bad.  I just reread your post. It works once and then the icon doesn't appear again.  Is this correct?  It's been awhile, but I remember having something like this happen.  My fix was getting the most up-to-date query related data tool online.
DougRulison
New Contributor III
Did you ever get a resolutio nfor this problem?  I am having the same issue and cannot for the life of me determine a pattern as a work around.  Did you get the latest tool?
thanks,
Doug
Any other idea?
Doug Rulison
by Anonymous User
Not applicable
Original User: drulison
I just downloaded the latest tool and i get the same results.  It always works on the first attempt, but subsequent attempts do not work, seems to be hit n miss.  I'm even selecting the same record and it does not return the "related records" tool in the popup.
Doug
by Anonymous User
Not applicable
Original User: gwalt_blm
Count yourself lucky.  With fresh install of Silverlight Viewer 3.1, the related table doesn't open at all.  Get a brief flicker, but nothing more.  As with you, the related tabular data from the feature access service shows up fine in ArcMap.  We have Silverlight v 5.120125.0 installed.  I made sure the web browser pop-up blocker was disabled, but no related attributes ever load.
GaryWalter1
New Contributor II
Quick update on my previous post - the feature access service has to allow the Create operation (in addition to Query and Update).  Once I enabled that setting in the feature access service, the related data table opened as expected.
MitchellWiniecki
New Contributor II
Does feature access need to be enabled to make the tool work?? I can't imagine so.  Never had luck with this tool.
