Attribute Table Widget Export CSV Issues
396
08-02-2022 11:35 AM
JimW
Occasional Contributor II
I have the filter widget in a web app along with the attribute table to show the attributes for the filtered features returned from the filter widget.  I have the attribute table widget configured to export to CSV.  When the user selects this option, they are presented with the 'export data to csv file?' window and if they click okay, the file does not download.  I have found that a small selection around 16 records will sometimes download but not always.  I have two separate people in two different offices using this and it sometimes work for one or the other or both or not at all, as is the case today.  Is anyone else experiencing this behavior and if so, is there a fix?  Thanks.
BethSeverin
I'm currently experiencing this issue, and my only guess is that it has to do with being unable to connect to the server.
Did you ever find a solution on your end?
