Background color for About Widget
3345
15
05-16-2019 12:29 PM
EmilyCaruccio
I have a logo that I can not change. Unfortunately, the logo is dark and does not go with the dark gray of the logo therefore I've been asked to change the background color to a light gray or white.
I've attempted to go to the common.css to change the color but I have failed.
Which rule will I have to edit to change the background-color of the widget? (Using Dart Theme)?
RobertScheitlin__GISP
Emily,
  This one:
.dart-panel .panel-bg {
    background-color: #4c4c4c;
EmilyCaruccio
I changed the color from #4c4c4c to #dbd9d9 within
Cleared my cache and the widget's panel still appears to be dark gray.
There is something overwriting that text. I just can't figure out where that is.
Are you adding the rule to the Bottom of the common.css?
EmilyCaruccio
I was not. I was just editing the downloaded code.
Since you suggested, I added .dart-panel .panel-bg {background-color: #dbd9d9;} to the bottom of the common.css, cleared my cache, and the background color was still dark gray. I added !important in hopes that it would work, and it did not.
Emily,
  Here is my rule at the bottom of my Dart theme common.css file:
  background-color: #c93434;
And what the app looks like:
EmilyCaruccio
I've attached my common .css to see if I'm missing something obvious?
(BTW: Thanks for all your help!)
Emily,
  OK this is what I get when I use your file:
EmilyCaruccio
That is exactly what I want.
I'm stumped as to why it is not reflected in my web app.
Is your app public?
