We have people that has been without noticing selected all objects and unfortunately changed attributes and lots of work to restore the data.
Steps to reproduce running Microsoft edge Version 104.0.1293.47 and Portal Enterprice 10.9.1
- Configure the widget against a vector layer and attribute then allow only extent tool for selecting
- Save and open the Webapp
- Select the extent tool
- Zoom in to one of the objects
- If you right click and drag the map at the same time (this is the trigger to the strange behaivor)
- Ignore the Windows popup and left click directly someware on the map.
Now it's selecting all the objects until maximum records of the service is reached.
You can see how many is selected to the left of the layername but its so small and when they are zoomed in they dosen't notice that alla are selected visualy in the map.
Is it possibile for you to reprocude this behaivor?
Possible to change the widget in the future? and have a configurable warning of maximum selections or in the Attribute pop-up show the number that is selected would also improve.
Regards
Micke
