Filter widget: zoom to features
3616
24
10-13-2016 08:36 AM
helenchu
Occasional Contributor II
Can I have the filter widget zoom to features ?   Thanks.
helenchu
Oh that 218 (points) was for the point feature polygon (my real app will have to use it)  .  The one I sent you returns only 1 polygon at a time.
RobertScheitlin__GISP
OK,
   But the url you proved was altered so I can not test using your data and as I mentioned with my polygon data it works fine.
helenchu
My server is not accessible from outside.   I use portal not Arcgis online.  I notice there're some differences from the two. Thanks.
Helen,
  My last reply should fix the issue.
Helen,
   OK so I found the difference between your data and mine that I was testing. Mine was using wkid 102100 like the maps wkid.
So make this change (line 6):
//Add RJS Now zoom to the results
      var qt = QueryTask(layerInfo.getUrl());
      var q = Query();
      q.returnGeometry = true;
      q.where = layerFilterExpr;
      q.outSpatialReference = this.map.spatialReference;
      qt.execute(q, lang.hitch(this, function(fs){
          this.map.setExtent(graphicsUtils.graphicsExtent(fs.features), true);
//End RJS‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
helenchu
That's what it is.  Thank you so much!
DavidTreering2
New Contributor III
The code changed slightly and the query is Null in the queryTask, causing it to fail, so then map.setExtent has no feature. Any ideas?
MelissaPrindiville
New Contributor III
Hi Robert, I am trying to apply this same functionality using web app builder filter widget.  I added your code above but I'm not getting any results.
Melissa,
   You are going to have a REALLY hard time adding this code to a minified version of the widget.js like you are attempting to do.
