Mark,
Here is what you will need to change.
1. In the LayerList widgets style.css. Add this new css rule.
.jimu-widget-layerList .div-content.layer-is-group{
font-size: 12px;
font-weight:bolder;
2. In the LayerListView.js: lines 95 - 98 are additions and line 101 is a change.
addLayerNode: function(layerInfo, level, toTableNode, position) {
var layerTrNode, layerTdNode, ckSelectDiv, ckSelect, imageNoLegendDiv, handle,
imageNoLegendNode, popupMenuNode, i, imageShowLegendDiv, divLabel;
var rootLayerInfo = layerInfo.getRootLayerInfo();
if(layerInfo.isRootLayer() || layerInfo.isTable) {
this._layerDomNodeStorage[layerInfo.getObjectId()] = {
layerTrNode: null,
layerContentTrNode: null,
layerNodeEventHandles: [],
layerNodeReferredDijits: []
var layerTrNodeClass = "layer-tr-node-" + layerInfo.id;
layerTrNode = domConstruct.create('tr', {
'class': 'jimu-widget-row layer-row ' +
( false ? 'jimu-widget-row-selected ' : ' ') + layerTrNodeClass,
'layerTrNodeId': layerInfo.id
domConstruct.place(layerTrNode, toTableNode, position);
layerTdNode = domConstruct.create('td', {
'class': 'col col1'
}, layerTrNode);
for (i = 0; i < level; i++) {
domConstruct.create('div', {
'class': 'begin-blank-div jimu-float-leading',
'innerHTML': ''
}, layerTdNode);
imageShowLegendDiv = domConstruct.create('div', {
'class': 'showLegend-div jimu-float-leading',
'imageShowLegendDivId': layerInfo.id
}, layerTdNode);
ckSelectDiv = domConstruct.create('div', {
'class': 'div-select jimu-float-leading'
}, layerTdNode);
ckSelect = new CheckBox({
checked: layerInfo.isVisible(),
'class': "visible-checkbox-" + layerInfo.id
domConstruct.place(ckSelect.domNode, ckSelectDiv);
imageNoLegendDiv = domConstruct.create('div', {
'class': 'noLegend-div jimu-float-leading'
}, layerTdNode);
var imageName;
if (layerInfo.isTable) {
imageName = 'images/table.png';
} else {
imageName = 'images/noLegend.png';
imageNoLegendNode = domConstruct.create('img', {
'class': 'noLegend-image',
'src': this.layerListWidget.folderUrl + imageName,
'alt': 'l'
}, imageNoLegendDiv);
if (layerInfo.isTiled || layerInfo.isTable) {
domStyle.set(imageShowLegendDiv, 'display', 'none');
domStyle.set(ckSelectDiv, 'display', 'none');
domStyle.set(imageNoLegendDiv, 'display', 'block');
domStyle.set(layerTdNode, 'width', level * 12 + 40 + 'px');
var layerTitleTdNode = domConstruct.create('td', {
'class': 'col col2'
}, layerTrNode);
var grayedTitleClass = '';
try {
if (!layerInfo.isInScale()) {
grayedTitleClass = 'grayed-title';
} catch (err) {
console.warn(err.message);
var layerTitleDivIdClass = 'layer-title-div-' + layerInfo.id;
var layerGroupClass = '';
if(layerInfo.getSubLayers().length > 0){
layerGroupClass = 'layer-is-group ';
divLabel = domConstruct.create('div', {
'innerHTML': layerInfo.title,
'class': layerGroupClass + layerTitleDivIdClass + ' div-content jimu-float-leading ' + grayedTitleClass
}, layerTitleTdNode);
