Host a Web AppBuilder (Dev) App on Web Server
6505
18
12-11-2015 09:17 AM
DeannaBurke
New Contributor II
DeannaBurke
New Contributor II
Yes, but, I need a port number for the redirect uri, don't I?
RobertScheitlin__GISP
Deanna,
  No once you deploy the app it does not need a port specified.
http://gis.calhouncounty.org/WAB/V1.3/widgets/eSearch/index.html
Step 7 needs to be updated in the app deployment help doc.
Jianxia Song
Jianxia
By default, the port number is 80 if you don't specify it.
Robert--I will make it clear in the doc by adding a note. Thanks for your reminder.
Jianxia
DeannaBurke
New Contributor II
I got it!!!
The redirect URIs should be http://[SERVERNAME] and https:[SERVERNAME], and the URL for the application should be http://[SERVERNAME]/appname.
Thank you so much for all your help!
Deanna,
  Don't forget to mark this thread as answered if you feel your question has been answered.
MegPeterson
New Contributor III
Hi Jianxia -
If you are updating the documentation for WAB DE I think it would be helpful to note that wherever you deploy the application it still needs access to the web map.
I was publishing my web map internally on Portal and thought after zipping up and downloading I could launch my app on a public facing server - that somehow zipping it up compiled everything together like Flex does.
Jianxia
Meg,
Very good point. I will clarify it in the Deployment topic.
Jianxia
Samy_PatricioManosalvas_Granja
New Contributor II
Hi Deanna
I am a beginner in ArcGIS
please I have a question:
it is a requirement of the WebAppBuilder have ArcGIS online or PortalArcgis?
Samy,
   Yes AGOL or local Portal is a requirement. For more details on Web AppBuilder see the help site:
Get started—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
