it is this line
//onBeforeUnload: function() {
// this.appStateManager.saveWabAppState(this.map, this.layerInfosObj);
to comment out two lines in MapManager.js
so that the layer is not turned off by close of browser window, and window opens again as normal.
It looks to edit widget also has problems similar to ?
Editor can not show, "read only layers" but only layers with edit abled layers:
but if you insert read only layer in editor.json config file, and sets them as read only, displays both read only and write in pop-up window by editing, as the old edition WAB DEV 1.2
