Identify Features
11678
21
12-17-2014 02:05 PM
MelanieHammond1
New Contributor III
Has anyone else experienced that identify still brings up a pop up for layers that aren't even turned on in the map? I am using a map published with Server and placed on ArcGIS Online.
MattMcGuire
I posted to soon. I moved the this.map.setInfoWindowOnClick(true); to the onClose function (line 317) and the draw widget now works.
This is a nice backup to have, but would prefer to see it in the AGOL version.
StanMcShinsky
Occasional Contributor III
Looks like both options are good. The reason I did it in the \jimu.js\dijit\DrawBox.js file is because that is where the clickEventHandler and clickEvent Listener are for the draw tool.
To use the code block you need to use the advanced editor.
JuliaGuard
Hey all,
Thanks for sharing this issue. It has now been identified and logged as a software bug in our system. The bug has been marked as "assigned", which means that the behavior is now under consideration to be fixed in a future release.
Hope this helps,
Julia
Esri Technical Support
TarigAhmed1
New Contributor III
I'm experiencing the same problem.
I'm using WAB on ArcGIS Online.
Jianxia
Above pop up issues with web map, measure and draw widgets have been fixed in the coming AGOL release and Developer Edition 1.1 in March.
Jianxia
AndySmith
Hi Jianxia, do you have BUG reference for this? Is it BUG-000084319?
SebastianRoberts
This still seems to be an issue with the WebApp Builder in Portal at 10.3.  Does anyone know when that will be fixed?  Unfortunately I can't use the develop edition with Portal because of another bug ( BUG-000086779 ).
RobertScheitlin__GISP
Sebastian,
    You will not see that bug fixed in Portal until you get 10.3.1 of Portal when it is released, scheduled release is approximately UC time frame.
by Anonymous User
Not applicable
Hi Jianxia
Can you confirm please if this bug was indeed supposed to have been fixed in the WAB Developer's edition 1.1?
I'm experiencing very similar problem using 1.1 - I have a web map with pop-ups enabled (the pop-ups in this web map work fine in AGOL, and also in a web app built using WAB Dev beta 3 edition) where none of the pop-ups appear to work in a web app built using WAB Dev edition 1.1.
All layers are enabled in the web map by default.
Cheers,
-Paul
Jianxia
Paul,
I just ran a quite test on dev edition 1.1 and popup worked fine. Does any popups  show up in your app? On the layer list, if you go down to the individual layer level, the context menu allows you to enable/remove the popups as well. Could you provide more details?
Jianxia
