Hi Torrin Hultgren
Thanks for reply.
If so, is there any point to building a settings screens for widgets?
according to that every 'save' to application the operator need to download it as zip and hosted in the IIS server ?!
What do you say about 'Hybrid' mode:
1. Host the folder C:\WebAppBuilderForArcGIS_2.7\server\apps in IIS
2. Need to change the api url at env.js file (in each app) - uncomment line 107
3. Continue to configure via the WAB SDK (Node app).
4.( after finish configure close startup.bat)
Is that make sense? or maybe there is other workflow?
The goal is to move the entire management (As much as possible) of the app to the portal interface so the operator can manage by him self most of the settings that relate to the app.
P.S
No, it's pretty clear that Esri doesn't intend to support WAB as a standalone multiuser solution and their answer to this question is a full-fledged Portal installation.
In which case you don't install the a full-fledged Portal?! How WAB SDK can work without portal?
How you will select Map?
A Lot of widgets 'talk' with portal items.. (Add Data widget for example..)
