Web AppBuilder for ArcGIS ("Web AppBuilder") is a web application designed to let you build powerful GIS apps without writing any code. Web AppBuilder also provides an extensible framework for developers to create custom widgets and themes. The jimu.js library is the core source code inside every GIS app made by Web AppBuilder. The core dijits and classes in jimu.js are documented at https://developers.arcgis.com/web-appbuilder under the API Reference and Guide tabs. We understand there is a lot to do in terms of documenting the extensible code in jimu.js and are working on a new system to enhance it.
