keep identify results (symbology) active when opening another widget?
2327
02-02-2016 05:42 AM
JasonStanton__GISP
Is it possible to keep identify widget (wab v1.3) results (symbology) active when opening another widget (from the header controller/off-panel widgets)?  For example, I have identified a community and it is highlighted on the application.  I want to open the print widget and print this exact view, but when I do the highlighting goes away.  Any assistance would be greatly appreciated!
RobertScheitlin__GISP
Jason,
  The Grsphics Layer (GL) is hidden in the widgets onClose event to prevent that just comment out the GL hide line in the onClose function.
      onClose: function () {
        this._hideInfoWindow();
        this.drawBox.deactivate();
        //this.graphicsLayer.hide();
        this.infoWinMouseOver.remove();
        this.infoWinMouseOut.remove();
Jason,
JasonStanton__GISP
Robert, I can't thank you enough for your help (on this and throughout the years)!  I really appreciate it!
LianaSmith
Occasional Contributor II
Hi Robert,
Is it possible to include not only symbology but the identify results as well to the print layout?
Thank you!
Liana,
  No the Identify Results can not currently be included in the print layout.
