Map click events and related WAB documentation
5917
01-22-2015 08:56 AM
HessCorporation
So i'm just kicking off my first WAB widget and immediately running into an issue trying to set map click handlers when the widget is opened. Looking through the esri coordinate widget i found this...
this.own(on(this.map, "click", lang.hitch(this, this.onMapClick)));
But I just can't get it to register the event, here's my full code...
define([
  'dojo/_base/declare',
  'jimu/BaseWidget',
  'esri/geometry/Point',
  'esri/SpatialReference'
function(declare, BaseWidget) {
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget], {
    // Custom widget code goes here
      baseClass: 'jimu-widget-customwidget',
      startup: function() {
        this.inherited(arguments);
  //this.mapIdNode.innerHTML = 'map id:' + String(this.map.getScale());
   onOpen: function(){
   onMapClick: function(event) {
  window.alert('map click');
     this.mapIdNode.innerHTML = 'map id:' + String(event.mapPoint.x);
I'm very confused why this isn't working.
Also does anyone know where i can find better documentation specific to the WAB? i also found this in the measurement widget and trying to work out the differences is giving me a headache, there seems to be a lot of methods/functions not found in the JSAPI and it would be nice to know what they are.
if (this.map && this.map.webMapResponse) {
          var handler = this.map.webMapResponse.clickEventHandle;
          if (handler) {
            handler.remove();
            this.map.webMapResponse.clickEventHandle = null;
Thanks all!
Richard
RichardThompson
New Contributor II
Managed to answer my own question, code is below for future reference, the issue was that i wasn't defining dojo.lang.
define([
    'dijit/_WidgetsInTemplateMixin',
    'jimu/BaseWidget',
    'dojo/_base/lang',
    'dojo/on',
  'dojo/dom',
  'dojo/domReady',
  'esri/tasks/query',
  'esri/tasks/QueryTask'
function(
    declare,
    _WidgetsInTemplateMixin,
    BaseWidget,
    lang,
    on,
  dom,
  domReady,
  Query,
  QueryTask
  return declare([BaseWidget, _WidgetsInTemplateMixin], {
      baseClass: 'jimu-widget-editor',
  onOpen: function(){
  this.mapIdNode.innerHTML = String(event.mapPoint.x);
  var queryTask = new QueryTask('*Service URL*');
  var query = new Query();
  query.returnGeometry = true;
  query.outFields = ['*'];
  query.geometry = event.mapPoint;
  queryTask.execute(query, lang.hitch(this, this.showResults));
  showResults: function(results) {
  var resultItems = [];
  var resultCount = results.features.length;
  for (var i = 0; i < resultCount; i++) {
  var featureAttributes = results.features.attributes;
  this.featName.innerHTML = featureAttributes.NAME;
  //window.alert(featureAttributes.NAME);
RichardThompson
New Contributor II
define([
    'jimu/BaseWidget',
    'dojo/_base/lang',
    'dojo/on',
  'dojo/dom',
  'dojo/domReady',
  'esri/tasks/query',
function(
    declare,
    BaseWidget,
    lang,
    on,
  dom,
  domReady,
  Query,
  QueryTask
  onOpen: function(){
CarlosSousaFerreira
New Contributor III
Thanks for this. It helped me too.
AndrewDavis5
New Contributor II
This helped me a good bit.  Thanks for sharing.
TimDine
Occasional Contributor II
Additional link that may be useful.  I found this page first, then the link below to show removing the event.
https://community.esri.com/thread/214607-how-to-turn-tool-for-mapclick-event-on-and-off
