Trying to create my first off panel widget, it would have no ui template just configuration, settings ui etc...
From what i read on this forum (yes the api documentation meantions nothing about this) you need to add your widget to the \client\stemap\predefined-apps\default\config.json
but in what format and to which element
According to the forum I
1. copied Scalebar widget (which is off panel widget), renamed it and changed name in manifest
2. went to config.json (mentioned above) and added a copy of scalebar widget items i found in this json
under
1.
widgetOnScreen.widgets
"uri": "widgets/Something/Widget",
"position": {
"left": 17,
"bottom": 25
"version": "0.01"
2. mobileLayout.widgetOnScreen.widgets
"widgets/Something/Widget": {
"position": {
"left": 7,
"bottom": 40
"version": "1.4"
I am left without any idea how to add off panel widget now.
Also when you want to deploy this to IIS for portal admins to use on their Portals will they have to write into these configuration files as well?
Best regards
