OSM Basemap
2946
07-24-2014 11:54 AM
EricPollard2
New Contributor III
Just noticing the Open Street Map basemap doesn't seem to be in the basemap widget... any way to fix this?
Thanks!!
Eric
Tags (1)
ZhifangWang1
New Contributor III
Unfortunately, missing osm is a bug of beta2, the only work round is to add it as an Item into Portal and using Lucas's way to add it to WAB.
LucasDorrough
New Contributor III
I noticed that too, I think you can add it to the portal if you are using it
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
EricPollard2
New Contributor III
Unfortunately I am not using portal, but regular AGOL. Thanks though.... maybe someone from ESRI can correct this on the AGOL end?
ZhifangWang1
New Contributor III
