I am using the Query Widget in my app and the data layer that I am querying has Related Tables attached. On set up of the Query Widget it offers the ability to configure the Query Results using the configuration set ouf for the pop ups in the web map. This comes through perfectly for the main layer popups, but when I select the related table information it seems to ignore the webmap configuration and pull all the titles etc straight from the MXD, this leaves me with fields such as Object ID apearing in the table which I don't want as well as ignoring the popup title configuration that I had set out to help differenciate between the realted tables. Is there a way to fix this or for me to manually configure the related tables popups in the query widget results panel?
Thanks
Maureen
