I am trying to create a simple parcel finder application using the Query widget in Web AppBuilder. I would like the user to search by Block, Lot, and Municipality to find a parcel (EX: Block - 10, Lot - 23, Municipality - Leonardville). The parcel layer being used is set up with Block, Lot, and Municipality Code columns but the user does not know the codes, only the names of the Municipalities. The tables are related and I can see that within the Web Map being used for the application. When creating a new query expression for the widget I do not see the related table as an option to search from. Is using a related table for this widget possible? Adding the municipality name column to the parcel layer is not a possibility.
Thanks.
