WAB 2.4 “New Report dijit ....”
1426
03-30-2017 07:12 AM
OlegLukyanov
New Contributor III
Is it possible to clarify
https://developers.arcgis.com/web-appbuilder/guide/xt-what-s-new.htm#ESRI_SECTION1_3F517CEB202A4C528...
“New Report dijit allows you to print a file with a map, tables, and supporting elements” ?
How can I use it when printing from WAB Apps?
Thanks.
RobertScheitlin__GISP
Oleg,
   I am not finding any existing widgets that use the Report dijit yet. It is a new dijit available to developers but as of yet there are no examples of it usage.
BillSpiking__GISP
See this post by @Nikki Golding: Web AppBuilder Reporting Widget.  I believe the Screening Widget developed by the Solutions team uses the dijit.
Environmental Screening | ArcGIS for State Government
DerekLaw
Esri Esteemed Contributor
All,
William's post is correct. I'm looking into getting more info about the Report dijit and will post an update when I have it.
Hope this helps,
DerekLaw
FYI,
Please review the API reference for the Report class here,
https://developers.arcgis.com/web-appbuilder/api-reference/report.htm
Hope this helps,
DerekLaw
FYI,
This blog post contains more info: Creating a Custom Widget for Web AppBuilder for ArcGIS using the Report Class
Hope this helps,
