Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/. |
I think that warning is for init.js:190
Chrome Version 51.0.2704.84 m (64-bit)
Win Server 2012 R2 Standard x64 (via Remote Desktop)
WAB Dev 2.0
3-d app editing. 2-d app editing is fine.
When I try to launch the 3-d app in Chrome from within WAB Dev 2.0, I get the same "3D web apps aren't supported" message, and then this in console:
http://myserver:3344/webappbuilder/apps/7/images/shortcut.ico Failed to load resource: the server responded with a status of 404 (Not Found)
(and indeed that icon file is missing from that directory, but if I copy that icon file in there from a 2D app, I still get the same error in Chrome)
If I use IE11, there is no issue editing 3D apps. There is also no issue when editing 3D AGOL apps using Chrome.
Note that my WAB Dev 2.0 has NOT been patched using 's patch. I removed that patch when the fixed version of Chrome was released. Should I apply that patch?
-Edit: applying the patch doesn't fix the problem.
