1. What version of WAB are you using AGOL, Dev or Portal?
Using AGOL
2. Are you seeing a pattern for your layers like all feature services show up but no Dynamic layers?
Actually, all my services are map services that allow query, but some show up in the Attribute Table widget config and some don't, which is what I didn't understand.
3. You mentioned that layers that have query ability show up but non others. Can you just turn on the query option then?
Also I believe you can always go to the layer list and add the tab to the table from there.
Yes, the attribute table can be viewed by going thru the layer list, but I don't think you can make permanent choices there, can you, like which fields to display? I'm basically confused about what services/service settings dictate what gets into the attribute table widget config.
Thanks for your response.
