Web AppBuilder Launchpad theme attribute table close problem
1036
06-28-2019 08:36 AM
MatthewMayfield
New Contributor II
I use the Launchpad theme for my web apps. I'm finding that when you close the attribute table, the space it occupied on the screen does not get returned to the map, but remains empty. Are others seeing this issue? I don't recall it seeing it in the past.
RobertScheitlin__GISP
Matthew,
   I am not seeing that issue are there any error in your browsers web console?
MatthewMayfield
New Contributor II
Thanks for your response, Robert. Yes, there is an error in the console related to the Attribute Table widget. It reads "d.tagName is undefined". See abbreviated screenshot. Any ideas based on that?
error messages in console
PhilLarkin1
Occasional Contributor III
If you have other layers in the app, does the same issue occur? I'm curious if the schema of the layer you are concerned about has been changed recently. d.tagname looks like it might be missing.
MatthewMayfield
New Contributor II
I think you may be right. The schema of the main operational layer has changed several times. Building a new app (I'm using Web AppBuilder) from the same map results in an error-free Attribute Table widget. Thanks!
