WEB v1.3 Release Date?
3382
11
10-14-2015 04:20 PM
StuartGrey1
New Contributor III
I was wondering if anyone could give a rough indication of when the next release of WAB (1.3) will be released?
Cheers,
Stuart Grey
RobertScheitlin__GISP
Stuart,
  Best I can say is this month. Bad Info
Stuart,
DerekLaw
Esri Esteemed Contributor
Hi Stuart,
We're planning on releasing Web AppBuilder for ArcGIS Developer Edition v1.3 in the early-mid Dec timeframe, after the next ArcGIS Online update (which is tentatively scheduled for sometime in Nov).
Hope this helps,
ChrisMathers
Occasional Contributor III
Ok this is sort of the timeline I was expecting. The AGOL update to bring vector basemaps into the mix and then a WAB update to incorporate the new AGOL functionality.
SebastienPelletier
The date is coming soon?
ChrisMathers
Mid December to early January is the official word from esri for the next WAB Dev. Ed. release.
DerekLaw
Hi Sebastien,
Web AppBuilder for ArcGIS Developer Edition v1.3 is currently undergoing final release certification testing. We anticipate its release sometime late next week or the Dec 14th week.
Hope this helps,
FrankVignati
will the next release work with the current online webapp builder? the webapp created now online will not import into the version of developer in use
Yes as both will be version 1.3
FrankVignati
OK, thanks, the error received implied version 1.4 for online edition:
Possibly unhandled Error: Some widgets are newer, import is failed. Name:[
Services Test]AnchorBarController,1.4,Header,1.4,OverviewMap,1.4,Zoo
mSlider,1.4,HomeButton,1.4,MyLocation,1.4,Coordinate,1.4,Scalebar,1.4,LayerList,
1.4,Legend,1.4,LayerList,1.4,Legend,1.4,Measurement,1.4,Print,1.4
    at Function.Promise.reject.Promise.rejected (C:\arcgis-web-appbuilder-1.2\se
rver\node_modules\bluebird\js\main\promise.js:275:21)
    at importApp (C:\arcgis-web-appbuilder-1.2\server\rest\apps.js:1:3231)
