WebAppBuilder Query Widget Date Bug
2645
05-06-2016 05:48 AM
ScottStopyak
Occasional Contributor II
It appears that the webappbuilder query widget has a showstopping bug when querying dates. I've formatted the date several ways now. Any which way I do it,  the query widget returns results for the wrong date. When the query expression is setup, it gives it a default date of today. You can't clear it. The results from running the query are always from the wrong day. One option I explored was picking the "unique" date from a dropdown but that isn't a viable option. For one it's cumbersome and secondly the dropdown isn't sorted correctly when you  use the most common date formats like dd/mm/yyyy. Has anyone ever found a way to trick this widget into working properly with dates?
RobertScheitlin__GISP
Scott,
  I do not have a problem using the query widget with dates. Can you be more specific?
ScottStopyak
It returns a date for the previous day instead of the day specified. I don’t know that its always the previous day. It may be whatever the day is when the expression is originally setup. I should also mention that our date fields will sometimes have hours minutes and seconds populated. Specifically, we have date/time for a scheduled inspection. Whatever date is selected from the calendar in the widget the results are returned incorrectly. I’ve tried to format it as a string instead of a date but that won’t work either.
Scott,
  The date being a day off it a pretty common issue for ArcGIS Server (not specific to WAB)
See this thread:
Web App Builder Date Issue
ArcGIS JavaScript Hack: Fixing Dates from ArcGIS Server
ScottStopyak
Thanks for shedding some light on this issue. So if I upgrade to 10.4 (giving me the ability to set a time zone) can I expect to resolve the issue or would it still require javascript date object hacks?
Scott,
10.4 will fix it.
