ArcGIS Workflow Manager Blog
102
21.1K
36
POST | Has anyone been successful in using a job extended property to populate the url for a send web request step? Doesn't ... by RyanDickinson1 New Contributor III 0 0 | 0 | 0 | 81 | |
POST | Hey all,Enterprise 11.2I'm curious if anyone has attempted to use Workflow Manager for 11.2? I'm not able to see any ... by CodyPatterson Occasional Contributor III 2 4 | 2 | 4 | 170 | |
POST | Hello,I have a survey that is connected to an existing hosted table in my 11.2 portal.I try to add this survey to the... by PierreloupDucroix Occasional Contributor II 0 0 | 0 | 0 | 120 | |
POST | We just transitioned to Workflow Manager Server and we are looking to create a Dashboard to track status and producti... by Ulises Occasional Contributor III 0 0 | 0 | 0 | 135 | |
POST | "Evaluate Data Quality" step does not show "Validation rules" error when running second time in the loop.We have "Eva... by MarkMindlin_idea New Contributor III 0 0 | 0 | 0 | 189 | |
POST | "Evaluate Data Quality" step does not show "Validation rules" error when with "Topology Rules"The Error Inspector whe... by MarkMindlin_idea New Contributor III 0 0 | 0 | 0 | 181 | |
POST | Workflow Manager Server on ArcGIS Pro 3.2, Enterprise 11.2We are using Workflow Manager Server with a step called “Ev... by MarkMindlin_idea New Contributor III 0 0 | 0 | 0 | 164 | |
POST | "Evaluate Data Quality" step does not work with Topology RulesThe Error Inspector when Validate shows an expected err... by MarkMindlin_idea New Contributor III 0 0 | 0 | 0 | 276 | |
POST | Hello Esri Community,I'm looking to tweak the default map extent in Workflow Manager Server. Currently, it consistent... by HatimKhayroun New Contributor II 0 0 | 0 | 0 | 175 | |
POST | Good afternoonI am looking for samples of Wokflow Manager Design Diagrams that show how to work in a versioned enviro... by JoseSanchez Occasional Contributor III 0 0 | 0 | 0 | 167 | |
POST | Can ArcGIS Workflow Manager be federated with more than one Portal for ArcGIS site? Or can only one instance of Workf... by sennaa94 New Contributor II 0 1 | 0 | 1 | 196 | |
POST | We are transitioning to Workflow Manager for Server. Since there is no reports functionality as in classic we are no... by Ulises Occasional Contributor III 0 1 | 0 | 1 | 160 | |
POST | We have an extended properties table to store the geographic area related to a job (ex. regions). Can you configure ... by Ulises Occasional Contributor III 0 0 | 0 | 0 | 170 | |
POST | Hello everyone,How to add Current User and Current date to Job Template Job Name?Thanks by SanchezNuñez Occasional Contributor 0 0 | 0 | 0 | 166 | |
POST | Using Workflow Manager on ArcGIS Pro 3.2 Enterprise 11.2I have created a very simple workflow with following steps : ... by StefanDieters1 New Contributor III 1 10 | 1 | 10 | 541 |
User | Count |
4 | |
2 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 | |
1 |
