Hi @HalaAbdelmaksoud @Ranga_Tolapi
Yes, we do have a fix around connectivity for Workflow Manager in the ArcGIS Pro 2.9.12 patch that will be releasing soon. However, that fix is specific to a bug where attempts to connect to the workflow pane in Pro took more than 10 seconds and then timed out (BUG-000164293).
If this connection failure is immediate or happening before that timeout, this fix would not resolve your issue. If that's the case, I'd recommend working with Tech Support to troubleshoot further.
Let me know if you have any questions.
Jonathan
