Cannot connect workflow manager items workflow manager pane
1877
15
01-12-2022 03:27 AM
HalaAbdelmaksoud
Hi all, I Cannot connect workflow items on ArcGIS Pro from the workflow manager pane, although it was working well before.
I am using a service-driven deployment pattern
Ranga_Tolapi
Hear from Esri support team, a patch 2.9.12 is planned to release end of February to address intermittent connectivity issues between ArcGIS Pro and WFM.
JFarmer
Hi @HalaAbdelmaksoud @Ranga_Tolapi
Yes, we do have a fix around connectivity for Workflow Manager in the ArcGIS Pro 2.9.12 patch that will be releasing soon. However, that fix is specific to a bug where attempts to connect to the workflow pane in Pro took more than 10 seconds and then timed out (BUG-000164293).
If this connection failure is immediate or happening before that timeout, this fix would not resolve your issue. If that's the case, I'd recommend working with Tech Support to troubleshoot further.
Let me know if you have any questions.
Jonathan
Ranga_Tolapi
Hi @JFarmer
Noted with thanks.
May I know what would be the new request timeout value towards BUG-000164293 resolution in the ArcGIS Pro 2.9.12 patch?
JFarmer
@Ranga_Tolapi
That connection timeout is now set to 2 minutes.
Jonathan
Ranga_Tolapi
Thank you, @JFarmer.
We have installed ArcGIS Pro 2.9.12.
Just curious, is there any configuration/workaround for users to extend the timeout value if required?
JFarmer
Sounds good @Ranga_Tolapi
Edit: We did make this timeout value configurable using a registry key change. We do not plan to make this process public but customers can contact Tech Support who can walk them through how to make the change if needed.
Jonathan
