Default Privileges on WMX
609
10-27-2010 10:09 AM
EdwardCopeland
The default priveleges under security do not show up after we do our install?  Any ideas or is there .jxl file we need to import?  I would Think they would just appear.
Thanks,  Ed
TopeBello
Occasional Contributor III
Hi Ed,
There are 2 configuration files (.JXL) that comes with the install of Workflow Manager. During post installation you can choose to import the minimum config (contains what you need to use the application) or quick start config (contains examples of workflow/job types/user/groups).
You can still import this to your repository from the Administrator by simply right clicking you Workflow Manager database after connecting to it and import configuration. Browse to <Install location>\config\Database Configurations
Hope this helps!
Tope
EdwardCopeland
Thanks Tope.  For some reason on the install the information will not load but after we go and point to the correct file all the priveleges work.
