WMX Search Tool Error
577
10-11-2016 08:28 AM
AnthonyBarron
Our team is trying to use the OOTB WMX search bar. All users are connected to the same Database; however only two users can actually use this functionality. The remaining users receive the error message below. The OOTB SQL query seems to be failing and I can't see how the SQL is constructed on the back-end to identify the problem. Does someone know what might be causing this? Or does someone know how the SQL statement is constructed?
"The executed query is not executing correctly against the database"
by Anonymous User
Not applicable
It likely needs to be fully qualified.
