One thing you can do right now, is add additional fields to your assignments layer. For example, you could add a field named "assetName". If you are creating your assignments automatically using scripts or whatever, then you would be able to populate this field (it currently won't show up in the Workforce Dispatcher Web Application). Then you can add a custom integration to survey123 which can be opened directly from the Workforce Mobile App. In the next release of the Python API (1.5), we have added an integration manager to the Workforce Module, this makes it easier to add custom integrations.
In the following example, I've added a new field titled "assetName" and then added an integration that passes this field directly to survey123 field named "field_0". The integration looks like:
{'id': 'survey123-custom', 'prompt': 'Open in Survey123', 'urlTemplate': 'arcgis-survey123://?itemID=a7d9a4895dc744feae0269d2cd43773a&field:field_0=${assignment.assetName}'}
Example code, using the new integration manager is available here: workforce-scripts/UC 2018 - 1 - Configuring A Project.ipynb at master · Esri/workforce-scripts · Git...
You can also add custom integrations (beyond what you can do in the Web App) by editing the project json manually in AGO Assistant.
