Unable to create new assignments in Work Force
383
04-22-2022 05:36 AM
DaveBodak
Hello,
I am working with this application to create a workflow for a hydrant maintenance crew. I was having some issues showing the feature layer on the mobile devices and was required to enable Sync to fix it.
Now, when I try to create an assignment, I am receiving the following message:
"There was a problem and the assignments could not be created. Please try again later."
The account trying to create this is a Dispatcher but also a Field Worker for testing purposes.
Thanks for your help!
CraigGillgrass
@DaveBodak can you invite the user "craig_sp" to your project as a Dispatcher?  That will allow me to take a look at the issue.
Craig
DaveBodak
Hi Craig,
When I attempt to add you as a dispatcher, I recieve the "Unable to add user" message on the bottom of the screen.
CraigGillgrass
Can you add other users in your organization to the project?
DaveBodak
No, I am unable to add any other members - even those in my organization.
CraigGillgrass
ok, is it possible to create a temporary user for me in your org?  I should be able to take a look at this then once you add me to the project as a dispatcher.
