ArcMap Output UTM as 3 fields
460
03-01-2022 08:33 AM
Labels (3)
BeckB
I'm using ArcMap 10.8.1. I have coordinates of points in decimal degrees, which I would like to convert to UTM and ultimately output to Excel. Since I want to output the coordinates to Excel, I'd like to have the UTM zone, easting, and northing as three separate fields. Is there a way to do this? I know the Convert Coordinate Notation tool can do the conversion, but it outputs the coordinates as one field.
JayantaPoddar
After projecting your data to UTM (assuming the points belong to a single UTM zone), you may use Add Geometry Attributes (Data Management)—ArcMap | Documentation (arcgis.com) and Calculate UTM Zone (Cartography)—ArcMap | Documentation (arcgis.com) (Add a Text Field "UTM_Zone" to the attribute table before running this tool).
Think Location
