I was wondering if there is any help documentation on how to export layers from Avenza as either a shapefile or a KMZ and bring that into ArcMap WITH the attachments/photos? Or if anyone has recommended work flows?
I’ve been able to export both a KMZ or shapefile and successfully add it to ArcMap. My question is, is there a workflow for getting the photos attached to the attributes in ArcMap? I can see the photo attachments in Google/ArcGIS Earth but don’t know how to get them attached to the features in ArcMap. Because when you export as a shapefile or convert the KMZ to a layer in ArcMap the images are not attached, they come in a separate folder.
I would think this is a common process used by many people but I have not found any workflows for doing this.
Thanks for your time.
Exported Shapefile
KMZ/L to layer result
