Failed Exporting from Enterprise GDB 10.6.1
8736
23
09-18-2018 05:56 AM
Lake_Worth_BeachAdmin
Occasional Contributor III
I am running ArcGIS Desktop 10.6.1 with SQL Server 2016 as my enterprise GDB.
When I import a FC into Arcmap from the Enterprise GDB and right click tyhe layer, export to shapefile I get the following error.
I can reproduce this behavior on ALL* 2k+ Feature classes in my database.
the only way for me to export a FC to shapefile is to do so via the Catalog Pane.
is this a known BUG in 10.6.1?
MichaelVolz
Esteemed Contributor
I am seeing the same error when exporting Oracle SDE feature classes out to shapefiles.  The Oracle SDE database is still version 10.5.1 as the desktop software is 10.6.1.  Did you already upgrade your SQL Server 2016 SDE database to 10.6.1?
Yes the SQL Server is running 10.6.1 geodatabase release.
I just tried to upgrade it again to verify and it failed stating that its already running the latest release.
BillFox
MVP Frequent Contributor
BUG-000115801
Workaround
  1. In the layers attribute table, select all the rows
Then try export again
meh, hassle in my workflow. do you know if this will be patched in the next 10.6.+ release?
BillFox
"the esri developer team is reviewing the bug"
bbieb
We also ran into this.  Seems to work fine in ArcCatalog.  Basic functionality broken.....
brian
Any response from ESRI addressing this issue?
bbieb
I had them add my Support call to the bug # above.  Their suggestion was to use a selection set.  My impression is that it wasn't a high priority since they had a work around.
brian
brian
by Anonymous User
Not applicable
We are seeing this error as well. We can export via ArcCatalog and Pro, and it works when data is selected first in ArcMap.
