Removing intersecting polygons
1516
02-24-2022 12:49 PM
Labels (3)
BeckB
New Contributor III
I'm using ArcMap 10.8.1. I have two polygon layers, shown below. I want to completely remove all of the purple circles that intersect any yellow circle. The Clip tool will only remove the area that overlaps with the yellow, but I would like to have the entire area taken out. How can I do this?
JayantaPoddar
MVP Esteemed Contributor
Using Select By Location
 Target Layer: Purple Polygon layer
Source Layer: Yellow Circle Layer
Selection Method: Intersect the source layer feature
Once Selection is done, you could just delete the selected feature parts (Turn On Editing, if required).
Think Location
JayantaPoddar
Think Location
ThiPham12
New Contributor III
You can also use the erase tool, which save you a step.
JeffHouser
In your post, you want to completely remove all purple circles that intersect any yellow circle.
To do this, you could do a spatial join of the Purple & Yellow  (join the yellow to purple), and specify your output as a shapefile and check-off the 2nd option.  This output shapefile would contain attributes from both layers.  Once the output is created, copy the dbf of the output into its own folder, then join the dbf to the purple layer.  Any feature from the purple layer that has attributes (non-null values) from the "Yellow" layer can then be deleted.
