3 combobox and multiple query
918
6
05-17-2010 09:02 AM
BarbaraRossi
I created a form with number 3 combobox.
when you press the search button, I do a search on the basis of
combobox choice, only 1 or 2 or all three.
This is the code I wrote and it works perfectly but only for a
case (Only one combobox is choice)
How can I add other combinations?
Can someone help me?
Thank you.
Private Sub cmdSearch_Click()
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pMaps As IMaps
    Set pMaps = pMxDoc.Maps
    Dim pCatastoStradeMappa As IMap
    Set pCatastoStradeMappa = pMaps.Item(0)
    Dim pInterventiLayerDef As IFeatureLayerDefinition
    Set pInterventiLayerDef = pCatastoStradeMappa.Layer(0)
    If cboStrada = " " And cboCodice = " " And cboProvincia = " " And cboSoggetto = " " Then
        MsgBox "Scegli almeno un parametro di ricerca"
    End If
    Dim strQuery As String
    strQuery = "Nome_Strada= '" & cboStrada.Text & "' or Codice = '" & cboCodice.Text & "'or Provincia = '" & cboProvincia.Text & "'"
    Dim pCatastoStradeActiveView As IActiveView
    Set pCatastoStradeActiveView = pCatastoStradeMappa
    Dim pCatastoStradeLayer As IFeatureSelection
    Set pCatastoStradeLayer = pCatastoStradeMappa.Layer(0)
    Dim pFilter As IQueryFilter
    Set pFilter = New QueryFilter
    pFilter.WhereClause = strQuery
    pCatastoStradeLayer.SelectFeatures pFilter, esriSelectionResultNew, False
BarbaraRossi
hello,
I better explain what it will do.
Attached are two photos that you show what can I do now.
I would however be able to do a search that lets you select any value of
any combobox and not just one.
I would add these other queries:
strQuery = "Nome_Strada= '" & cboStrada.Text & "' and Codice = '" & cboCodice.Text & "'and Provincia = '" & cboProvincia.Text & "'"
or
strQuery = "Nome_Strada= '" & cboStrada.Text & "' or Codice = '" & cboCodice.Text & "'and Provincia = '" & cboProvincia.Text & "'"
I tried with if then else cycles but the result is always and only, the first choice in the cycle if.
Sorry if I was not too clear.
Thanks.
JamesCrandall
MVP Frequent Contributor
hello,
or
Thanks.
I think you mean you'd like If/ElseIf statements based upon the values in the ComboBoxes?  Maybe something like:
If Not cboStrada.Text = "" Then
  strQuery = "Nome_Strada = '" & cboStrada.Text & "'"
ElseIf Not cboCodice.Text = "" Then
 strQuery = "Codice = '" & cboCodice.Text & "'"
ElseIf Not cboProvincia.Text = "" Then
 strQuery = "Provincia = '" & cboProvincia.Text & "'"
Else
 msgBox("No values set in any of the ComboBoxes!")
End If
BarbaraRossi
Hi James,
thank you very much for your reply.
I tried your solution, I'd already done myself.
The problem is that always runs
ie the first statement.
Even the message box appears when I make any choice.
Maybe the rest of the code is wrong.
I try to put everything.
thanks again.
Barbara
    Dim pMaps As IMaps
Else
MsgBox ("No values set in any of the ComboBoxes!")
End If
'Create a QueryFilter for the first argument of the SelectFeatures method
'Make the selection with the SelectFeatures method
'Create an RGB color and set its Red property to 200
    Dim pRedColor As IRgbColor
    Set pRedColor = New RgbColor
    pRedColor.Red = 200
'Set the states layer's Selectioncolor property = the RgbColor object
    Set pCatastoStradeLayer.SelectionColor = pRedColor
Dim pLayer As IFeatureLayer
Dim pFSel As IFeatureSelection
Set pLayer = pCatastoStradeMappa.Layer(0)
Set pCatastoStradeLayer = pLayer
'Get the selected features
Dim pSelSet As ISelectionSet
Set pSelSet = pCatastoStradeLayer.SelectionSet
Dim pEnumGeom As IEnumGeometry
Dim pEnumGeomBind As IEnumGeometryBind
Set pEnumGeom = New EnumFeatureGeometry
Set pEnumGeomBind = pEnumGeom
pEnumGeomBind.BindGeometrySource Nothing, pSelSet
Dim pGeomFactory As IGeometryFactory
Set pGeomFactory = New GeometryEnvironment
Dim pGeom As IGeometry
Set pGeom = pGeomFactory.CreateGeometryFromEnumerator(pEnumGeom)
pMxDoc.ActiveView.Extent = pGeom.Envelope
pMxDoc.ActiveView.Refresh
End Sub
Private Sub cmdReset_Click()
    cboStrada.Text = " "
    cboCodice.Text = " "
    cboProvincia.Text = " "
    cboSoggetto.Text = " "
End Sub
Private Sub UserForm_Initialize()
'così inserisco oggetti nei vari menù a tendina
    cboStrada.AddItem "SP424"
    cboStrada.AddItem "SP001"
    cboCodice.AddItem "06BP"
    cboCodice.AddItem "03A"
    cboCodice.AddItem "PR02"
    cboProvincia.AddItem "AN"
    cboProvincia.AddItem "PU"
    cboSoggetto.AddItem "S1"
    cboSoggetto.AddItem "S2"
    cboSoggetto.AddItem "S3"
End Sub
JamesCrandall
Barbara,
You could try getting the SelectedText or SelectedValue of the Combobox instead of trying to get .Text...
Something like this (I can't remember the exact statment to use and will have to test tomorrow):
If Not cboStrada.SelectedText = "" Then  ' Or try cboStrada.SelectedValue
ElseIf Not cboCodice.SelectedText = "" Then
ElseIf Not cboProvincia.SelectedText = "" Then
Else
End If
BarbaraRossi
Hi James,
i don't know how to thank yuo.
without your help I would not have ever made.
I write the correct code for all who need it.
thanks, thanks, thanks
Barbara
If cboCodice.SelText <> "" And cboStrada.SelText <> "" And cboProvincia.SelText = "" Then
    strQuery = "Nome_Strada= '" & cboStrada.Text & "' and Codice = '" & cboCodice.Text & "'"
ElseIf cboCodice.SelText = "" And cboStrada.SelText <> "" And cboProvincia.SelText = "" Then
ElseIf cboCodice.SelText = "" And cboStrada.SelText = "" And cboProvincia.SelText <> "" Then
ElseIf cboCodice.SelText <> "" And cboStrada.SelText <> "" And cboProvincia.SelText <> "" Then
ElseIf cboCodice.SelText <> "" And cboStrada.SelText = "" And cboProvincia.SelText = "" Then
ElseIf cboCodice.SelText <> "" And cboStrada.SelText = "" And cboProvincia.SelText <> "" Then
    strQuery = "Provincia= '" & cboProvincia.Text & "' and Codice = '" & cboCodice.Text & "'"
ElseIf cboCodice.SelText = "" And cboStrada.SelText <> "" And cboProvincia.SelText <> "" Then
    strQuery = "Provincia= '" & cboProvincia.Text & "' and Nome_Strada = '" & cboStrada.Text & "'"
Else
End If
JamesCrandall
Hi James,
Barbara
I'm happy to hear you got it working, Barbara!
